a bunch of issues
well first off i just bought a 2000 f250 from an auction.unfortunetly i didnt get to hear if it ran or not.but its a good thing i only paid 500 for it. i do know that four injectors are bad. when i start it up lots and lots of unburnt fuel come out of the exhaust. following a pretty good amount of oil.its is also popping out of the intake which is probably caused by the four cylinders not getting fuel.i think the turbo probably needs to be rebuilt.but i was just wondering what else could cause these issues.
spray ether into the intake and see if it does that when all 8 cylinders are getting fuel
if not.. soak a rag in ether, diesel |
I would use wd-40 not ether, but thats my :two cents: .....
here's a ![]() a tech should be by to tell you more
i forgot to mention that when i get it it didnt have the actual intake. i believe that dirt probably ate up the turbo.and there is quite a bit of blow by at idle.
and i also forgot to mention that the smoke was burning the crud out of my eyes and smelt like straight raw fuel.the coolant level didnt really drop that i have noticed.
sounds like that trucks been through alot so......
yeah i would guess it has been.but for the price i paid for it...i couldnt say no.even if i have to dump 4 grand into it.
nothing else guys?
do u have any codes? can u at least get a idea of where your leaking? clean up with a wet dry vac wipe it all down then try to find source
