very urgent! need help!! - Ford Powerstroke Diesel Forum
Old 09-26-2010, 10:45 AM
ok so what do you guys think this is...I'm stranded in a parking lot trying to figure this out. My 03 f250 started leaking fuel by the gallon almost! I was sitting at a stoplight and started smelling strong diesel fuel. Looked out the window and had a huge puddle on the ground. Pulled off to a restaurant and it continued to pour out until I shut the motor off. Most of the concentration of fuel comes from the fuel bowl area. I replaced the fuel filter about 3 months ago and never bd an issue with it leaking. I just put my dp tuner on a week ago so I wonder if it just built up pressure going through the tunes or what.....?
Help would be appreciated!...cause I'm stranded with my crackberry haha
Old 09-26-2010, 08:56 PM
check your fuel line that runs by your oil pan on the drivers side the fuel line is held to gather by a clamp mine came loose and i had a trail of diesel from my house all the way to the shop. you need a special pair of pliers to clamp it back into place hope this helps.
Old 09-26-2010, 09:23 PM
Check the lever on the back of the fuel bowl. It should be pressed up against the bowl which is the closed position.
Old 09-27-2010, 12:36 AM
also check the gasket? maybe u didnt tighten enuf and ballooned it out
Old 09-27-2010, 01:31 AM
ARMY MOM!!!!
Send a message via Yahoo to korg70kbc
check the fuel regulator on the right side of bowl also, they have a spring inside which likes to break & the o-rings go south too.
regardless the bowl has a few o-rings that occasionally just let go
good luck
Old 09-27-2010, 02:19 AM
Almostdunfukinwidit
Check the water in fuel drain. Orings probably gave out
Old 09-28-2010, 08:26 AM
When you don't have access to the right parts and the fuel/water drain is leaking you can take it off and flip the orings over, I have done this on 3 different truck and had it stop the leak.
