have no clue what to do - Ford Powerstroke Diesel Forum
Old 06-10-2007, 01:22 PM
Send a message via AIM to Marks7.3stinks
ok .. I dont know how to make a new post so maybe you can help me this way.
I have 01 7.3 .. once warmed up ... it looses fuel pressure and wont run ... just sputters bucks and so forth. I changed the cam sensor, fuel pump and filter. It is still doing it. ford delear said it was the pump because lack of pressure.
M
Old 06-10-2007, 01:30 PM
At the top right of the forum you are browsing, just look for the words Thread Tools and click on it -- then scroll down to the Post a New Thread and WaLa!
as far as your issues... I have no clue - but a fuel pump does seem to be what I'd think is causing from the symptoms you've reporte.
Old 06-10-2007, 01:32 PM
Hey Mark, moved this for you, so you should get more responses in this section. Just go to the top ofthe page you want to post in, you will see a button that says post new thread, hit that and start your thread, that simple.
Can't help with the problem, but someone will be along to help that knows what they are talking about hahaha.
Gord.
No ides on the truck problems, but I will give ya a free bump.
to the ORG!!
Old 06-10-2007, 01:34 PM
thanks for moving it to the right place for me ..
Old 06-10-2007, 01:36 PM
On another note... when I put the key on, I can hear the fuel pump on the frame making noise until the relay kicks in, and stops it. However, I hear it sputtering when running, and not running smoothly. But I just replaced it ? i'm so frustrated with it.. someone help me out
Old 06-10-2007, 01:37 PM
No problem Mark, you might want to go to introductions and say hi to all the other folks, great bunch around here, most love to help out when and how they can. Good luck.
Gord.
