ton of smoke - Ford Powerstroke Diesel Forum
Old 09-23-2010, 08:49 AM
ton of smoke
blowing smoke out the dip stick and the oil fill motor cutting out blowing blue grey smoke a lot clears up some at higher speed already changed injecter o rings help a little but not much lost now oh and the outer day It all of the sudden cleared up ran perfect then back to the same **** whats up with it
Old 09-23-2010, 02:50 PM
O.I.F. Combat Vet 11B
Compression test will tell you all you need to know. sounds like you are in the same boat I am, needing a rebuild.
Old 09-23-2010, 02:53 PM
sounds like u got too much blow by just givin ya bump
Old 09-23-2010, 03:09 PM
too much blow by, sounds like your rings are gone
