returning code 1211 - Ford Powerstroke Diesel Forum
Old 08-31-2010, 08:21 AM
Question returning code 1211
Heres my problem. I work for a transit fleet. We have an 03 7.3 in in a 450cutaway chassey. The problem is a reoccureing code 1211. What we have done so far is replaced the fuel pump & all filters includeing ones in tank,replaced IPR & ICP. Swapped out ECM.The oil is replaced ever 45days and the same oil is used in our intire fleet.I have cked fuel pres at both heads and its running no less than 55psi under load. We have a MODIS Snap on scanner and I have graphed ICP & IPR and have determined that the problem is a high spike in oil pres @ wot or under load.When codes flaggs the IPR is being commanded by the ecm to go as high as 65% durning this spike. Vehical is at dealer now but they are scratching *** also. Anyone out there have any suggestions???We are also not useing any aftermarket perforemence devices. Vehical is stock. Thanks Votran John
Old 08-31-2010, 03:25 PM
Some info here -> help code p1211
Old 08-31-2010, 03:49 PM
Possible injector O-ring issue. ICP blowing past the O-rings causing the IPR to be commanded to 65% to keep up with ICP demands.
Old 09-01-2010, 08:18 AM
code 1211
If this were the case wouldnt I be loseing oil to the fuel system. I,m not exsperanceing any oil lose or any sign of oil in fuel. I,ve looked in the tank. I would also think I would see some kind of back pres when I did my fuel pres ck. Thanks anyway. Votran John. PS You do make one validite point. Maybe Its not so much a high spike as a droop before the spike. I.ll have to regraph my condition.
Your right If the top Oring goes bad Icp pres Blows back to the crankcase not the fuel system.
