What fuel pressure should I be running? - Ford Powerstroke Diesel Forum
Old 08-20-2010, 09:27 AM
Question What fuel pressure should I be running?
Hello All,
Below I have listed as to what I've done to my truck (see signature). I've installed stage 2 DIY single shot injectors. I had the fuel pressure regulator shimmed, but continued to blow injector o-rings. Since I've removed the shim, and am hoping to alleviate the issue but would like to know what the proper fuel pressure should be?
Also, I am curious about knowing what would be a good aftermarket fuel pump? I thought I'd heard of one call "Fazz" or something like that. And curious to know if they have an adjustment for fuel pressure build right ino the pum?
Thanks!
