AC Question Blows cold when stopped, stops while driving until it hits 60mph. - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-18-2010, 12:35 PM Thread Starter
Fireman Crawler's Avatar
My brother-in-law has a 2000 7.3 Manual. He is having a problem with the AC cutting out. It will work sitting still. When he shifts through the gears it will stop blowing cold air, once he hits above 60 mph it will start blowing cold air again. Once the truck drops below 60 it stops blowing cold air (blows warm air) until it comes to a dead stop. Has anyone ever heard of this before?
Fireman Crawler is offline
post #2 of 6 Old 08-19-2010, 07:37 AM Thread Starter
Nothing????
post #3 of 6 Old 08-21-2010, 12:05 PM
cliffordbigred's Avatar
It may be low on 134a. Mine did the same thing so I put some in. use a gauge to make sure I did not over do it.
cliffordbigred is offline
post #4 of 6 Old 08-21-2010, 12:27 PM
Quoted: 5 Post(s)
also may be A/C clutch, check airgap on clutch, shim if necessary
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #5 of 6 Old 08-22-2010, 01:56 PM
ZachBoyer's Avatar
Adjusting Clutch Gap on the Ford FS10 Compressor
2005 F250 6.0 King Ranch Crew Cab Short Bed 4X4
-MODS-
4" Turbo Back Straight Pipe
Sinister EGR Delete
Sinister Coolant Filter
Cat EC-1 Coolant
ZachBoyer is offline
post #6 of 6 Old 08-25-2010, 02:57 PM
Quoted: 3 Post(s)
also check your coolant level. Ford trucks have a sensor if low on coolant or if cooling system gets above certain degree the a/c compressor shuts off. It happened to me and I thought it was low freon but no. It was low coolant.
erbilabuc is offline
