Hmmm Alternator or Starter? - Ford Powerstroke Diesel Forum
Old 08-16-2010, 05:13 PM
I started having some problems with my truck starting. I would have to jump it with 2 vehicles to get it started. Eventually I bought 2 Duralast Gold batteries. This was about a month ago when I got the batteries. It started better at first but still seemed to turn over very slowly. After a week or 2 the starts were pretty hard again and last night it barely turned over enough to get it started.
I did a volt check and it was 12.4v before starting, it dropped down into the 9volt range and once started and running it was in the mid 13volt range and was slowly climbing.
So obviously it shows a charge. Now is that charge enough? Or is the starter getting old and drawing too much voltage and needs to be replaced?
Any other ideas on how to test them would greatly help...Thanks.
Also I don't think I have anything draining on the battery because even if it sits for just 20 minutes, it still struggles to turn over.
Old 09-05-2010, 09:37 PM
Thanks for the replys....but I bought a new starter and that was the problem.
Old 09-05-2010, 09:45 PM
Your welcome
Had i seen this last month, i would have told you right off your starter was bad. This happened on my last truck. Current truck, when it started to happen, i didnt let it finish to tell me, new batts and starter after that and no issues since
Old 09-08-2010, 04:45 PM
Lifetime Premium Member
I had the exact problem with mine a couple weeks ago.
