Throttle Position Sensor - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-15-2010, 11:01 AM Thread Starter
My throttle sensor keeps failing. I have a 2000 F350 Powerstroke (automatic) that keeps failing, i think there is a problem other than the sensor.
The throttle will not responded at times but when in cruise control the truck runs normal.
I installed a new sensor (pedal assembly) about 6 months ago and it lasted for about 3,000 miles. Then started having same problems. I figured I may have received a bad part so I exchanged it with for for a new pedal assembly. This assembly lasted 500 miles and is having same problems.
What else could be causing the sensor to not respond. I have a programmer installed but have not had any issues with it.
kacy132 is offline
post #2 of 3 Old 08-16-2010, 08:54 PM
Does that programmer have a plug that goes in between the male and female part of the TPS?
My Edge does and if yours does also, that could be a solution.
Early 99 PSD CC LB 4x4
Volant Intake
Full 4" Exhaust
PHP Phoenix
35's
Justin.Hutch is offline
post #3 of 3 Old 08-16-2010, 09:17 PM Thread Starter
I have the Delta Forces - Sniper Diesel programmer. It is a normal computer programmer rather than a chip that install after the computer. There are no wires just the program that you upload
kacy132 is offline
