ANYONE HAVE ANY IDEAS?
Ok let me give you the run down....02' F-250 7.3L 260,000 miles. Oil changed every 3,000 miles. Cranks fine..no blow by out the oil fill cap! Runs for about 30 min. then just dies... pull code P603 kam error. I have 3 brand new CPS's a blue, black and grey. I have tried all three and still have the same results.
Changed fuel filter, air filter, 2 new batts. Also its stock was running superchip but pulled it out to see if it was the problem but still does the same. If you have any ideas please send them my way! Thanks in advance for your help! |
Check with dealership, there was a cam sensor recall on my late 99.
You gotta get it on a scanner and see what's going on when it dies... (certainly Not a CPS issue if you've tried 3
)You know, you need a specialized scanner for our engines, a "regular" OBD-II isn't going to help. |
Kam error is a memory error in the PCM
It normally occurs if you have a chip or programmer. Try removing them if you have them. Or your PCM is shot. |
Thought he pulled the programmer with the same results...
