Help no left turn signal but have brake light
ok to start blinker was flashing like crazy so first thing i thought.. Blown blub but replace still not working thought maybe the socket was bad nope tried the other side that work still not working.. Next i replace the turn signal switch and same issue.. Looked at the wiring and the plug on the back of truck was rotton.. So i replaced it now i have left brake but still no rear left turn signal front works but fast blink.. Replaced the flasher in the dash still same issue any input would be great thanks!!!!
anyone????
Each turn signal has it's own fuse.
I think you have a bad wire somewhere. If the the front one flashes fast and you have brake lights then you know it's not the fuse, bulb, or socket. I would start at the light and work your way forward looking for corroded or broken wires or spots where the insulation on the wire bulges a little telling you that it's corroded under the insulation. These spots you can usually pull apart with your hands. Common spots to corrode are anywhere there is a splice or connection.
