Cranks w/RPM but no start & no pressure
Truck just died, like the key being turned off while driving. Did have a cam shaft code but is still showing low oil pressure -replaced CamShaft sensor, HPOP, and oil pressure sensor -fuel is flowing -chip is disconnected I have read forums but looking for something I missed. Shaun '99 F250 7.3 PSD 180k Last edited by sbain; 05-17-2007 at 10:29 AM. Reason: add info |
Welcome to the site, did you check the oil level in the hpop. I know you said you replaced the sensor.
I am sure some one will be here soon that can help you out. |
Oh yea....I am new to post but have visited before. Previously had a no fuel problem and FYI - the problem ended up being the pickup tube on the inside bottom of the tank had been knocked loose when I had to run over a construction cone.
Have you checked the actual fuel pressure? You say it is flowing, but I wonder if it does not have enough pressure.
