boost leak
i tightened up all the clamps on intercooler pipes and gave me about 2 more pounds of boost but i think i should get a couple more pounds .... anything else you would recomend doin thats easy fix... tighten or checkin and help is appreciated thanks
mike |
midnight bump
You could get new CAC boots. But if you have it good and tight, there should not be an issue.
ya tightening helped it for sure... gained about 2 psi .... so no i can hit 20 consistently but i still think i should being seeing at least 24-26.... i no im forgetting something though... there is something else check
Have you checked where you are getting your reading from. The MAP line and all that?
mine is coming from the map line
afternoon bump?
Have you checked to see if the up pipes are leaking where they come into the collector for the turbo??
haha well i was doin the foil delete and what do you no there is black streaks running down the side of the up pipes right where they connect to the turbo so i have a slight exhaust leak? anything i can do for a quick fix
Quick?? In a word NO. You have to replace the exhaust doughnuts. I have read that a 2" chevy doughnut gasket works really good. I've also heard that if you put alot of copper anti-seize on the gaskets it helps keep it sealed longer. I havent tried any of these yet but sometime this week when I take the turbo off to install my new pedistsal I will replace the gaskets then too so I'll letcha know how it turns out.
