Check Engine - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-09-2007, 12:42 PM Thread Starter
Check Engine
ok, have had the light come on a couple of times now, fluid levels fine, guages are good, could this indicate that the fuel filter needs replacing or the air filter needs cleaning or even both? seems to be running fine during both occasions, then once you stop and kill it, when started again no light.
fourx4forfun is offline
post #2 of 6 Old 05-09-2007, 12:44 PM
im fat and ugly
stump0331's Avatar
next time it come on go to auto zone and have them pull the code that will narrow it down
2004 Excursion
stump0331 is offline
post #3 of 6 Old 05-09-2007, 01:07 PM
ADMIN AND TECH
SCUFFY828's Avatar
check engine light has nothing to do with air or fuel filter , like stump said get the codes pulled first , go from there
ITS STOCK
SCUFFY828 is offline
post #4 of 6 Old 05-09-2007, 03:26 PM
<<---"Shadow"---
sea71's Avatar
Just ideas here, but if youre chipped, overboosting could cause a light(solved by a map fooler), or could be an ICP pressure issue also from a chip.I was informed thats why mine still does it.
Shane
2011 F250 Crew Cab FX4
STOCK!
sea71 is offline
post #5 of 6 Old 05-10-2007, 03:52 PM Thread Starter
thanks guys, its crazy, both times i am just cruising, not doing anything crazy, nice steady speed, then that comes on, then once stopped, restart it and it does not come on, so hopefully next time someone is with me so can go to the Zone and they can keep it from getting stolen while it is runnin while i run inside to get someone to check it.
post #6 of 6 Old 05-11-2007, 10:34 PM
ridgerunner98570's Avatar
country boy
Having to worry about someone stealing your rig while you're getting help is the reason I don't go to the big city! Thats why you buy a code reader and do this in the safety of your own place. I know they are not cheap, but you will use it quite often. Maybe if some of your friends have a powerstroke then you can go halves. Just a thought.
99 4X4 Superduty extended cab Centurion 7.3 factory turbo Powerstroke, Edge Performance Chip, 2013 Harley Davidson FLHTK Ultra Limited Electra Glide. "Kilt Wearing Old Fart Biker"
ridgerunner98570 is offline
