need help
I have a 99F-350 7.3 constance miss #6 cyl. I have diag. no broken rings no smoke compression 295lbs other cyls 300lbs rocker arms ok pushrods ok injector buzz test passed. KOEO pass KOER pass #6injector replaced twice were do you go from here?
the 99.5 had an issue with the wiring harness under the valve cover it probably melted.
I'm not a tech.. so I really can't help with your problem. What I can do is bump this back to the top so the techs are more likely to see it by saying:
Welcome to Powerstroke.org
wiring harness were replaced ecm replaced cps replaced fuel pump replaced fuel tank cleaned oil pump pressures ok whats next? every thing says to replace #6 injector again special ford lube was used last injector change
valve cover gaskets and harness were replased. thanks
Ouch
Thats a lot of money so far. Anyone test the IDM yet?
