Poor Fuel Economy Loss of Power ??? Answer Found - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-19-2010, 04:20 AM Thread Starter
Read my story and pass it on if your truck seems louder and no as peppy and or fuel economy and power seem to have crept up on you here is the annswer!!!
HELP LOSS OF TURBO PRESSURE AND PEP LOW MPG
2001 F-250 4-WD SuperCab 3.73 rear end Automatic tranny.
NO CODES IN COMPUTER...
I just had the tranny rebuilt at 60,000 miles ford motor company and your crappy Mechanical Diode..nuff said.
OK I just ordered a tripple guage set Boost/Pyro/Tanny temp.
I feel my truck has lost some of it's *** since I bought it in 2004 with 22,000 on it feels little laggy on the turbo and not *** much OOOMPH when I punch it to pass people ....idles fine and runs decent just seems like it lacks power or maybe boost pressure ...why I ordered the guages I also feel like I'm getting really crappy fuel mileage like 12-15 mpg I have a sending unit acting goofy reads over-full at fill up and low fuel light with more than 5 gallons in tank so I just go by miles/gallons at fill up for my reading data.
I know getting guages is the first step low boost pressure will tell me if I have a leak or turbo or wastegate issue ...truck is 10 yrs old so something could easily have an issue someplace a sensor or something as well I'm decent with tools ect so I like to do the work myself if I can oh did I also mention I'm broke thanks to the economy lol who aint ....
I would like to iron out the issues I have before I even attempt to do any kind of chipping or mod ...would like to get better mileage and power if thats possible without hurting truck ..it will be paid off this year lol and I already ate a big 2,000 wiener on the tranny rebuild ...did I mention (nasty word replaced) ford motor company lol.
Can you guys give me some points and maybe some on the cheap mods to do after I get the guages installed ?
Any help would be appreciatted greatly I miss my truck running like it used to and my fuel milage being so crappy is a bummer too.
I can't find a decent diesel mech here where I live in cincinnati and the local garages will BS you and play parts changer...my mother had a radiator failure in her car ...120.00 for new radiator ....a garage tried to charge her 600.00 for replacement ..if I would have been there the guy would have been cold ****ed on the spot ....luckily she found a raditor shop to do the job for 300 ....the lack of integrity in the auto buissness anymore is sickening ......sorry to rant
Update 4-15-2010
OK-Glowshift Guages installed
Here are my readings as of this AM
Truck is not towing anything but my 200 lbs ***....
Muffler has been deleted
EGT SENSOR INSTALLED BEFORE TURBO
4-15-2010
1500 -2000 RPM 40 % pedal depressed accelerating under load
600 degrees EGT
4-6 PSI boost pressure THIS IS NO GOOD
2000 RPM 70 % pedal drepessed accelerating under load
600-700 EGT
8-12 PSI boost pressure THIS IS NO GOOD
3000 RPM wide OPEN THROTTLE accelerating under load
800-900 EGT
14 PSI boost pressure WIDE OPEN THIS IS NO GOOD
What is going on based on these readings ?? LOL NO GOOD IS WHAT
I removed the cooler to intake boots and cleaned and reclamped them do not appear to be leaking I still want to do the foil delete on the turbo to cooler tube and clean/check/retighten that one as well as install the napa air filter deal....to repalce the stock airbox.
I would appreciatte any help you guys can give me I miss my old truck plus I'm thinking about a tuner of some type ....not until i get her back to square one though.
Not trying to be a Prick....but...
If the turbo is laggy on takeoff and the truck doesn't have the pep it used doesn't everything point in the direction of leaking up pipes/gaskets the truck has 65,000 on it fresh oil and filter change ....
What is the top boost given from a powerstroke of my make and year giving when eveything is running 100% good.
Is someone saying they had 27 lbs of max boost on a stock setup total BS or what ?
If the gaskets are leaking should it stand out like a sore thumb ?
I have a small mirror and a flexible borescope ....I was just uner the truck putting in the EGT sensor last night didn't really focus on the bottoms where the gaskets are on the up pipes I will look tonight for any soot or holes ect
This problem developed gradually and now it's affecting my takeoffs from a stop ie getting out into traffic or overtaking people on the highway ...i used to blow peoples doors off also fuel mileage is rally crappy under 15 mpg I knew people getting 19 or 20 on stock trucks ....
I don't want to alter anything until it runs like it should stock!
UPDATE 4-16-2010
Remove stock air filter and drove it into work this AM 10 miles tops yeah I know not the best .....anyway here is latest I am definitely doing the MOD with the napa air filter where do you put the sensor? in the short piece of pipe u have made between filter and rubber boot?
The truck had more power and pick due to no restriction BUT the BOOST NEVER GOT ABOVE 14 PSI EVER....
EGT GOT UP TO 900 when I was hammering on it ....
I drove my buddys 2000 F-350 last night and it was way quiter than mine ...and had more pickup which really leads me to believe I have leaking doughnuts on the up-pipes ......has anyone had success replacing these without spending 400.00 plus on the IH flex pipes ??? I see beans makes a set of brass gaskets for 85.00 someone said chevy 350 gaskets from napa will work and they are like 10 bucks for a set ....
I cannot see any soot anyplace but it sounds loud from a cold startup alot of noise from the front end even with muffler deleted I wish I knew a decent diesel mechanic in cincinnati or exhuast shops ...alot of flim flams around here it's sad ...the stealers / dealers will soak you too...
Need help just a noob who wants his baby purring again 6 payments left on truck lol..
Guess what Passenger side up-pipe was leakingbad and drivers side was on it's way too !!!! no wonder my turbo wasn't making boost!!!
I spent all day saturday under my truck after soaking the boltg friday night with PB blaster use this or you will be using a torch to remove the bolts and buying a new collector housing due to bolt being broken off inside hole and cracked housing this was the one that leaked to I'm thinking housing cracked and started leak buy letting threads slip and the threads are trash DO NOT REUSE UP PIPES they are 100.00 for both pipes new from dealer and I am calling about collector "baby's butt fitting on back of turbo for price today when dealer opens I will post prices later today i tried to tig weld up pipes where gaskets rubbed metal away and NO-GO you need the exact alloy rod or else the metal bubbles up I had stainless rod and it still looked horrible and if it leaked or won't fit due to distortion you will be very pissed off this job sucks *** I am also going to probably go with international harvester up pipe kit if collector fitting brings me even close to 300.00 I never want to do this again Exhaust work blows bigtime if you have no lift!!!!!
scott52575 is offline
post #2 of 7 Old 04-19-2010, 11:36 AM Thread Starter
Found problem leaking up pipes
OK up pipes were leaking ..... NO exhaust pressure on turbo means no low boost on low end and low on high end max boost was 14 psi wide open and really low uder 2500 rpm... it doesn't take much of a leak to kill your power on this truck and your mileage.
OK it took 8 hours to try and get these babys out after doing it by the book PB blaster 1 day ahead and during removal only to have the last bolt break inside the collector housing/babys butt and ruin the casting.
THIS IS WHAT YOU DO EVEN IF YOUR BROKE like I am.
1. GET A OXY-ACYT torch carefully cut the bolts off the manifolds underneath easy as pie then use an impact to remove the bolts in the collector/babys butt if they break off all the better.
2.remove clamp on babys butt that joins it to back of turbo.
3.Take all of this and throw it in the trash immeadiately.....
4.Call BRIAN at Black Widow Diesel shipped new bellowed international harvester kit all fittings and bolts no gaskets to leak ever never have to do this job again...... 460.00 all in yes it's expensive but he is a mechanic who runs his shop/parts buissness and knows his stuff call him up he spent 45 mins on phone with me explaining stuff and answering all my questions.. I called 3 other places and nobody felt like answering the phone let alone answering questions one place did answer but wanted 100.00 more for bellowed kit plus knew jack s about my truck ect. just parts peddlers .....ill pass
I called ford first to get a price on all the parts 150.00 for new babys butt ...50 for each up pipe without flanges without bolts without gaskets add another 50.00 for that so were at 300.00 plus tax for the same crap that leaked before and will leak again ask anyone do a google search on up pipe leaks and everyone says throw them away and use bellowed IH kit
BY THE WAY I called IH dealer in Dayton OHIO and they wanted 1200.00 for this kit I luaghed in her face .....
THis job sucks to much to ever do again don't go cheap charge it if you have to .......listen to people on these sites they know stuff.....
post #3 of 7 Old 04-27-2010, 06:43 PM
Send a message via AIM to PatDoody
damn my truck sounds like its doing the same thing yours is doing... same numbers on the guages and everything. ugh not wanting to do this repair haha
PatDoody is offline
post #4 of 7 Old 04-28-2010, 08:05 AM
OHBandit's Avatar
Scott you running a tuner? I'm getting crappy mileage...think I'm gonna check my up-pipes.
2003 F350 Lariat Crew Cab 8' Bed 4X4 7.3 PSD
4" Pro Comp Lift
MotoMetal 951's W/Toyo MT 35X12.50's
Power Hungry FU Chip
ITP 4" Ported Compressor Housing
4" Turbo Back Exhaust Straight Pipe
S&B Air Intake W/Zoodad mod
Pillar Gauges: Boost, Trans Temp, Exhaust Temp
6.0 Trans. Cooler
Recon smoked cab light lenses
LineX Bed Liner
OHBandit is offline
post #5 of 7 Old 04-29-2010, 10:27 AM Thread Starter
NOt running any tunes at all bone stock
post #6 of 7 Old 05-31-2010, 06:25 PM
How did you tell the up pipes were leaking? Was there black around the flange or what?
Thanks
Duane
DIY Intake
Issopro egt,boost,trans.
4" summit exhaust.
PHP 6 position chip with 45 tow 65 tow 80 tow 65DD and 100Perf
Stancor mod.
Duanesz is offline
post #7 of 7 Old 05-31-2010, 07:55 PM Thread Starter
Basically
There was no soot around my pipes ....but I noticed the exhuast being louder inside the cab my passenger side was the culprit the drivers side was starting to go as well but there was no soot at all ....I am thinking about making up a device to put air pressure on the system and hokey as it souds maybe putting a smoke bomb in so you can visually check the exhuast side of the turbo for leaks
any leaks will kill turbo drive pressure which in turn robs you of boost and MPG/POWER I just got home from having my tranny rebuilt again ...right this time ...I still may have an issue or two with either the HPOP or the Low Pressure Fuel Pump/System not completely satisfied yet
I am going to work through this until i get things right MPG and Performance wise before I even atempt to put a tuner on my truck!
