Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems
Old 04-15-2007, 11:07 PM
stroked outlaw stroked outlaw is offline
Send a message via AIM to stroked outlaw
strange problem-intermittent throttle problem
I have a 2002 f 350 and today while driving along when i let off the throttle and tried to step on it again there was no responce. It was dead, even if i pushed it to the floor, but if i let it up all the way and stepped down again, it would work normally. It also did it in park if I pressed it slowly. any ideas? maybe a pedal assy.? It seems to be getting worse.
Old 04-22-2007, 10:39 AM
Sabre2th Sabre2th is offline
Sounds like pedal assy to me.
Old 04-22-2007, 11:23 AM
Jon
Tournaments Won: 1
Posts: n/a
Yeah,
thats actually pretty common. I have replaced atleast a dozen pedal assemblies.
Old 04-22-2007, 01:06 PM
thanks, already changed pedal assy.problem solved!
Old 04-23-2007, 11:43 AM
FasTruckMonkey FasTruckMonkey is offline
Send a message via AIM to FasTruckMonkey
Can you guys elaborate more on that?
Old 04-23-2007, 02:13 PM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
power stroke engines are controlled by what i call fly by wire setup , no cables or linkages engine controlled by pcm which gets its signal from the tp sensor mounted on accelerator pedal inside , the higher the reading the pcm gets from the tp sensor , the higher the engine revs , the tp sensor can go bad , truck will crank but wont go any where when goes out
Old 04-23-2007, 02:38 PM
red73psd red73psd is offline
^^^^^ how hard is it to replace cause mine is going out and i beleive im going replace it soon
Old 04-23-2007, 04:22 PM
very easy , 3 10 mm bolts , unplug , plug back up take you just a minute
Old 04-23-2007, 05:30 PM
sea71 sea71 is offline
Hey Scott, can this sensor go partially out?? Or is it a situation where its either good or bad. No in between? Just curious if the first part of the pedal movement can go out and then pick up about a third the way down. Thanks.
Old 04-23-2007, 05:48 PM
Jon
Tournaments Won: 1
Posts: n/a
Yes Shane
It sure can. I actually have 3 assemblies in my tool box that I know will work well enough to get somebody home. However on 2 of them you have to smack them with your foot some times.
