Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems
  #11 (permalink)
Old 04-24-2007, 03:56 AM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
Originally Posted by sea71 View Post
Hey Scott, can this sensor go partially out?? Or is it a situation where its either good or bad. No in between? Just curious if the first part of the pedal movement can go out and then pick up about a third the way down. Thanks.
absolutley can just depending on where the bad spot is in the tp sensor , most generally if it is acting up it will give a code but may not turn the light on
  #12 (permalink)
Old 04-24-2007, 05:48 AM
FasTruckMonkey FasTruckMonkey is offline
Send a message via AIM to FasTruckMonkey
After I went home yesterday I did some exploring and found out what you guys just said. I didn't realize these things had an electronic throttle. Is the pedal assembly a pretty expensive replacement?
Also while I was down there exploring, I found a micro switch behind the go pedal similar to what you would see with a nitrous kit. Is that factory?
  #13 (permalink)
Old 04-24-2007, 06:13 AM
not factory , someone may have ran propane or nos at one time
  #14 (permalink)
Old 04-24-2007, 06:24 AM
Is there anything else that the micro switch could be used for? I cant really think of anything else..but the PSD are all new to me.
  #15 (permalink)
Old 04-24-2007, 07:16 PM
clmtng clmtng is offline
Beer Drinker/Ballast Guy
I've been having the same issue with my pedel; however, I checked the voltage and it seems to be fine. Could it be going out or is it just time to bite the bullet and replace it?
  #16 (permalink)
Old 06-14-2007, 09:47 PM
stroked outlaw stroked outlaw is offline
Send a message via AIM to stroked outlaw
well,replaced the pedal assy. 3 months ago and it went bad allready. the dealer replaced it under a part warranty, and i am back on the road again!! just dont know for how long?
  #17 (permalink)
Old 06-17-2007, 03:08 PM
I replaced mine as well and so far it seems to be working fine; however, I did it about a week ago and now I'm in South Dakota with the National Guard and won't be able to drive for at lease another week or so. Let's just hope that it works from now on...
  #18 (permalink)
Old 07-03-2007, 04:18 PM
garlicbreath garlicbreath is offline
The 97 I just bought from the city water and lighting side has a micro switch on the pedal, kinda like the brake light switch on the brake pedal.
So I wouold say it's factory unless the city is putting propane or nitrous on the work trucks!
Where do you get a TPS or pedal assembly?
Can you replace just the sensor?
