Weird leaking problem
i am almost positive my water/fuel drain valve is leaking, i drained some fuel for the first time (previous owner did not, 276k miles on it) and it seems to only leak when i let it idle a bit. it just drips, if i go it seems to stop dripping, and it doesnt drip when it is off. anyone know what could be the problem?
I would just replace it... There only like 30 bucks.
You can try to put new seals in it but i never had any luck with the rebuilds.. |
It's a common problem you can buy the kit from for ford or you can get the o-rings off e-bay you need 2 o-rings #202 Viton & 1 o-rings #013 Viton.The min, order is quan. of 25 each. It will cost you about $11.oo total. Viton is the material of the o-ring it's for diesal & high heat. There is a video back on this web.site that shows you step by step how to install them, I watched the video last week .
Its really ez to change them out takes about 10 min... thats getting the step latter out too... LOL
yeah its not bad to change them. Is it leakin from that tube?
