Where can i find this part?
My truck is leaking fuel. And its coming from the drain. I've read that you can change just the o-rings or the entire drain valve. Can i get just the orings from the dealer, and can i get the entire drain from anywhere else besides the dealer or is it a dealer only part? I need to fix it ASAP because i have to use it for work monday. I doubt i'll have any luck at the local parts store, but i was just curious where you guys got your parts to fix this problem. Thanks!
YOU CAN GET THEM FROM A LOCAL FORD DEALER. LIST IS LIKE 50 DOLLARS IF YOU HAVE AN ACCOUNT OR GET A DISCOUNT ITS ONLY LIKE 30 IT COME COMPLETE AND IS LABELED AS REBUILD KIT
its not a fix, but if you are in a jamb, take the torx bolts off the drain valve and remove it. Drain it first. Then get a piece of inner tube and place it over the o-rings. A strip of rubber works. Then put the bolts back in and tighten down. THis stops the leak. However, you wont be able to drain it til you fix it right.
Replacement O-rings for Ford Diesel Engines has great prices and ships fast. he's cheap. Wont take more then 10 minutes to do it. The tox is a t-15 i believe. You will need one on the end of a 1/4 ratchet. Theres 4 bolts, well screws, a screwdriver type wont work. |
I just took the old o-rings to a local hydraulic shop and they matched them up to new ones. Cost me a whopping $2
local hyrdaulic shop or ebay are the cheapest places. the "kit" that ford has is to dang expensive.
Thanks guys. I'll see what i can find in the morning. It has leaking on occasion, But lately since its been really cold it leaks very bad! It just pours out in the mornings when its bone cold. Its the coldest its been here in Louisiana in 14 years. My truck doesnt know what the hell is going on. haha.
If you remove the drain and flip the o-rings the other way it will stop it for a little while til you can get new ones.
