wipers wont turn off - Ford Powerstroke Diesel Forum
Old 01-08-2010, 02:36 AM
wipers were on due 2 weather pulled up n my drive way turned truck off wipers keep wiping i had 2 pull 30 fuse which is #106 2 make them stop any ideas thanks. its a 2002 f-350, thanks
Old 01-08-2010, 03:55 AM
I had a similar issue where my horn went off in the middle of the night. I thought someone was trying steal my truck but actually i pulled out the access panel for the fuse block and felt water on top of the fuse box. A common problem is leaky windows on fords i had a small spot when i rained just right the water would get it. Not sure if this will help but you never know.
Old 03-22-2010, 08:47 AM
I'm having this same problem right now on my 02 Excursion. What ended up being the fix?
Old 03-22-2010, 03:29 PM
Just did some more troubleshooting. With the switch on the column unplugged, the wipers still work on their own. I'm guessing this points to the motor being the culprit???
Old 03-25-2010, 06:09 PM
BUMP! Does anyone have any ideas? I've been reading about a possible "pulse board" on the motor?
Old 03-25-2010, 06:58 PM
Sounds like its your GEM. I know my 2001 F350 the GEM controls the wipers, 4x4 and a few other things. On the 2001 the GEM is on top the fuse box. Sometimes when the windshield leaks water it drops onto the GEM then into the fuse box. Just a thought.
Old 01-19-2011, 10:29 PM
having same problem with my 09 350
I am having the same problem with my 09 350 has any one found a fix yet. Mine just started today at work.
Old 01-19-2011, 10:56 PM
I had a 2001 F-150. I got a chip in the windshield which led to a leak in the weather stripping which happened to make the horn go off constantly until I unplugged it. Long story short expensive *** computer needed to be replaced. Hopefully, don't have the same luck. The horn never worked the same and needed to be replaced multiple times. I don't like telling this to people because Ford's are a lifestyle for my family and they have always treated us well. I would never drive anything else other than Ford trucks. Good luck man.
Old 01-19-2011, 11:16 PM
Still have warranty so hopefully if it is that they will cover it
Old 01-19-2011, 11:22 PM
I would hope so. In Montana they have always taken care of my family. Numerous Fords we have bought so they are pretty good about stuff like that.
