Filter drain o-ring leak or something else?
As it's gotten colder over the past several days I've noticed these larger and larger puddles of fuel under my 2001 F-250 Powerstroke.
![]() Crawled under the truck this afternoon and see fuel dripping out behind the oil pan. There's a metal cover there that has a drain hole in the bottom and there was a steady drip coming from it ![]() Here's another shot of that area by the starter and oil pan. ![]() I move to the area where the fuel filter drain line terminates under the truck and I can see there's been some leaking there, but nothing like the back of the engine. ![]() I look up by the fuel filter and I can see diesel in the valley. I can't see anywhere it is obviously leaking up there. ![]() It doesn't make sense to me why all of the diesel would be in the valley if it was the fuel filter drain valve o-rings. Wouldn't the fuel drain out towards the front of the vehicle if that was the case? Last edited by hammer1995; 01-06-2010 at 04:26 PM. |
If it is the o-rings,crank the truck and see if it is leaking from that area.(should be easier to see while it has pressure ).WATCH OUT FOR MOVING PARTS THOUGH>
Yep my bet is on the O rings, you can replace just the O rings or by the whole valve assembly for $40 or so. I would get a flashlight and a mirror on a stick and check for the leak location, just turn the key on, you don't need to start the truck to look for a fuel leak.
If it is the o-rings it will leak into the valley. It comes from the housing that holds the yellow plastic handle to the filter housing. The o-rings are easy to replace and if you go onto dieselorings.com, you can get them very cheap. I got the whole fuel kit (about 9-10 o-rings) for $11 shipped.
I just replaced the Orings on my drain today. Its not a hard job but its a PAIN to work in that little area. Check out Replacement O-rings for Ford Diesel Engines
Mine is doing the same thing! But i need to fix it ASAP because its a work truck. Can i get just the O rings from the dealer or am i going to have to by the entire drain valve? Is the drain valve a dealer only part or can i find it at the local parts store? DO you guys know?
dealer only...
Actually, the problem is so common that Dormon has gotten in on the game. Dorman part 904-202 available by special order at Autozone - they want $73 for it. I sure wouldn't buy one from them - but is isn't just at Ford anymore.....
what is the price at the dealer?
From the Wabash Ford Dealership website:
Fuel/water separator, f250 pick-up, 7.3l diesel - 1999-07 super duty - 1999-07 SUPER DUTY 99-03 List $45.32 Retail $33.72 |
