hammering - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-05-2010, 04:14 PM Thread Starter
hammering
Had it parked outside for a few days abot 0 degrees. It started fine but after it ran for a while it started hammering and running like crap. Service engine soon light came on. Any ideas? Ran fine when I parked a week ago
early 99 stroker
afe stage 2 dry intake
5 inch exhaust
diy boost fooler
old hypertech programmer(i think its as old as I am)
33's on 20's
4 inch lift
bandit1 is offline
post #2 of 8 Old 01-05-2010, 04:24 PM Thread Starter
went out and tried it once more. after started it runs normal for about 10 seconds the the svc engine soon light comes on and immediately starts hammering and shakes the whole truck. almost feels like its missing.
early 99 stroker
5 inch exhaust
diy boost fooler
33's on 20's
4 inch lift
bandit1 is offline
post #3 of 8 Old 01-05-2010, 04:34 PM
Tony V's Avatar
Changed the CPS lately?
2000 F-250 216k- smoke much?
Facebook: Anthony VanCamp
Add me if you'd like
Tony V is offline
post #4 of 8 Old 01-05-2010, 04:36 PM Thread Starter
pretty sure that was changed at the dealer. seems to me i got a recall on that. i think it was about a year and a half ago. doesnt explain to me why it just started this.
early 99 stroker
5 inch exhaust
diy boost fooler
33's on 20's
4 inch lift
bandit1 is offline
post #5 of 8 Old 01-05-2010, 07:12 PM
Just a thought,go ahead and start it,then unplug the icp sensor (internal control pressure)and see if it smooths out-it puts the truck in like a failsafe mode.
See if you can have the code read if that doesn't work.
How many miles are on the truck?
icysmooth is offline
post #6 of 8 Old 01-06-2010, 06:20 AM Thread Starter
ill give that a try today. 217,000 for miles
early 99 stroker
5 inch exhaust
diy boost fooler
33's on 20's
4 inch lift
bandit1 is offline
post #7 of 8 Old 01-06-2010, 06:29 AM
injection direction's Avatar
I have had this happen when the Under Valve Cover Gasket Harness goes bad.
Visually inspect the connectors going into each side of the valve covers. Unplug them and look for any burned or black looking connections.
These are the wires that control the injectors and glow plugs. They are constantly bathed in oil inside the valve cover and are known to short and fail after the miles add up.
Injection Direction
1999 (early, 10/98) F250 XL CC/LB 4WD 4R100, str8 pipe, CCV mod, bypass trans filter, 3.73, DIY napa air filter, 261k
1995 E350 XLT str8 pipe, SS (super stocker), 321k
No replacement for displacement
injection direction is offline
post #8 of 8 Old 01-06-2010, 07:47 AM
Powerstroke Junkie
NCHornet's Avatar
Checking both sides of the UVC harness should be a first step, and you can try unplugging the ICP, hey it's free, but to be honest why not get your codes read? This will point you in the right direction.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
