Injectors 1 & 8 - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-04-2010, 09:06 PM Thread Starter
Injectors 1 & 8
Tried to find something similar in other posts but you can never find the exact scenario.
I have an '03 7.3 with 210,000 miles. It is my daily driver. No engine mods at this point. Last Thursday I was driving down the street and it began running rough like it wasn't getting fuel. Truck died and wouldn’t restart. Suspected fuel filter so I changed it before calling for help. Wasn’t the filter. Towed to the Ford garage. Got word this morning that injectors 1 & 8 were bad probably due to poor fuel pressure and 1 & 8 are the last to get fuel. They did a test on the pump and it had good pressure but poor volume.
So now they are replacing the pump and two injectors($1900). I just had the HPOP replaced approx 1 month ago (about 2,000 miles) ($1100). Should I be expecting the other injectors to have problems? At 210k miles does it make sense to upgrade the injectors to a higher performance then stock? Could something have gotten hosed up during the HPOP change out?
Appreciate any ideas.
stutler is offline
post #2 of 5 Old 01-04-2010, 09:16 PM
bklecan's Avatar
Did they check fuel pressure.
bklecan is offline
post #3 of 5 Old 01-04-2010, 09:31 PM Thread Starter
Thye said fuel pressure was fine but the volume was poor. they didnt give me any numbers.
stutler is offline
post #4 of 5 Old 01-05-2010, 08:50 PM
bklecan's Avatar
At 210,000 miles if you haven't done any injectors yet i would recommend doing them all. The high pressure pump if only a month old should be warranty depending on who did it. If it was the same shop it should be warranty.
bklecan is offline
post #5 of 5 Old 05-18-2010, 04:43 PM
payne5757's Avatar
Ever get this fixed? I just received the same diagnosis after my truck was hit by a drunk driver and started running badly
2000 Ford F250 Super Duty Powerstroke ( 7,460lbs 5in rough country lift, 18in XD Revolvers, 35in Dura Grapplers, bilsteins all around, 4in.MBRPstraight pipe,WW,TS 6 pos chip,TS Monitor w/HUD,Tymar,map fooler,foil delete, zoodad, Kenwood stereo, pioneer 6x8s, JL 500V1 amp, and one JL12w7)
payne5757 is offline
