Radiator/Transmission Line Fitting - Ford Powerstroke Diesel Forum
Old 01-01-2010, 02:09 PM
I finally was able to replace the radiator and water pump yesterday as well as do a complete flush and replace with an elc and I have a small leak where both the transmission lines go into the otw cooler inside the radiator. The hard lines go into a fitting which goes into the radiator. The new radiator came with the brass fittings however no matter how tight I get the fittings there is still a small leak. Has anyone had this problem before? The only solution I see is to wrap the threads with teflon tape. Even then I don't know if it will work. Any help would be appreciated.
Old 01-01-2010, 03:26 PM
Send a message via AIM to jhaddox
are there any crush washers or anything?...i know ive missed a crush washer on a calliper before and it drove me nuts and leaked till i figured out out
