Motor stalls in the rain?? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 12-29-2009, 11:01 PM Thread Starter
Ok, newby to the forum but not to the truck. I have an 01 Platinum with 305k on it. This year it just started dying only when it rains. I can be going down the road at any speed or even idling at a light and if it is raining it will randomly just die. No warning, its like I shut the key off. All of the other electronics keep working. I can just put the truck in neutral, start it, and back into drive and I am good. The problem is definatly only if it is raining out. Also, when I start it in the mornings sometimes when I turn the key over to start it just "clicks". I have to turn the key several times and finally it will fire. It has done this for almost a year now. Seams that when it is colder out the start issue is worse as in I have to "click" it a few more times......any help??
jdsteve is offline
post #2 of 10 Old 12-31-2009, 07:33 AM
Powerstroke Junkie
NCHornet's Avatar
When it does this check the starter relay on the pass fender well and see if you have 12 volts going to the starter. As for the raining issue, the windshield are known to leak on the drivers side and water can enter the PCM and cause all sorts of problems, so check for moisture in that area.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #3 of 10 Old 01-01-2010, 07:52 AM
pinkfloyd's Avatar
Send a message via MSN to pinkfloyd
I had the same problem awhile ago. I found that the cps can cause this. It has something to do with the amp draw of the wipers. I replced the cps with one from the International dealer and have had no problems since. On a side note it only did it when the wipers were on intermitent.
2002 f-250 4X4 XLT 7.3,
stock tranny
DP-Tuner F6 chip
mbrp ss 4" turbo back exhaust
diy intake with zoodad mod
3 pilllar guage setup with autometer guages Thanks Raul
valve body
boost fooler
NEXT ON LIST
torque converter
pinkfloyd is offline
post #4 of 10 Old 02-02-2010, 06:28 AM
99.5stroker's Avatar
I am having this same issue.....what a mess. Only sputters with delay wipers on...180 miles of a recent trip was full of coughs and sputters from my rig because I had the wipers on driving through a bizzard, the other 200 miles was issue free asside from the occasional stall or rpm pulse when copming to a stop. It had a post recall cps in it when this started happening and now it has a napa cps in it because it felt like the last time the CPS failed. I can sit in my driveway with a dry windshield and flip the wipers to intermitant and after a few flips the truck dies...its not the same number of on/off revolutions everytime but it is defintely tied into the wipers...
99.5 CC, LB, 4X4, a few mods.....
98 VW TDi, 5spd, Custom 3" CAI, Sprint 520's, "modified" exhaust, H&R Cup Kit, 52 mpg's.....more to come...
99.5stroker is offline
post #5 of 10 Old 03-19-2010, 02:20 PM
See 1999 F250 7.3L 4x4 Engine Dies, No Speed Control
There seems to be a lot of us with this problem.
imjohn is offline
post #6 of 10 Old 03-19-2010, 10:27 PM
I replied to your post.....
post #7 of 10 Old 11-04-2010, 05:45 PM
Sorry for bumping this older post, but it was very helpful in solving my CPS issue. 1999 F-250 2WD.
FYI - I tried to replace my CPS with the aftermarket ones from both Pepboys and Autozone. Both CPS's resulted in the same stalling symptoms. I finally ordered the ford CPS from ebay. The Ford CPS worked.
Thanks again to everyone who posts in this forum, it was a big help.
doofyskier is offline
post #8 of 10 Old 11-15-2010, 01:03 PM
I had the same problem with the cps I bought from napa. the one I bought from international fixed it.
steve
stevel34 is offline
post #9 of 10 Old 11-15-2010, 01:54 PM
Stroken7.3's Avatar
Put some dielectric grease on the cps plug, it will help keep the water out. I've had that problem also and that was how I fixed it.
2001 F-250, 6 speed trans, BDP Tunes, Autometer Ultralite gauges
Stroken7.3 is offline
post #10 of 10 Old 11-15-2010, 02:36 PM
Quoted: 134 Post(s)
Feedback Score: 3 reviews
For what it's worth,,,, I think the issue with the CPS/Rain connection had nothing to do with water, but rather that the wiper motor was generating some EM signal that was interfering with the CPS signal
NoRalPh is offline
