Truck Acting Crazy
I was slowing down to turn into the gas station and once I turned in and started to give it throttle it wouldnt do anything. I held it to the floor and it just idled. So I changed settings on the chip and it started missing and finally died. Cranked and cranked and finally started back. It run like crap so I turned it back on the 140 setting and it sounds like it has single shots or something or huge cam. any help is aprieciated. codes are
P1280 P0198 P0113 P1690 P0475 P0340 P1210 P0541 |
i cant help you with the codes, but it soundes like an 02 sensor located just below the injector bar and valve cover on the drivers side. easy to replace. you should go to a diesel shop, not ford and for about 35 dollars they will diagnose for you . and you can go home and fix it. if it is o2 sensor. replacement is under 100.00 dolllars. gl
02 sensor?
here ya go |
have you pulled your chip out yet? i'd try that first
