Need help on my 02 f350
i have a 2002 ford f350 with the 7.3l diesel that while cold and warming it up runs fine ounce warm and in park or neutral it has a crazy idle where the rpm bounce around until it shuts off here is what ive done to mine to try and fix the problem
new hpop new icp sensor with connector new ipr sensor with connector new cam sensor new waste gate new fuel pump made sure the spring that on the side of the fuel bowl didnt have trash in it did the in tank fuel mods to get rid of them pesty screens in there and non of this has done anything for the truck im thinking now that its a head gasket problem but im not sure im gonna send some oil off to have it tested to see if there is any antifreeze in the oil any help from you would be awsome my next step is getting rid of the truck witch i dont want to do but no one can figure it out also on my truck the check engine light comes on when your on the highway and hit about 70 and stays on its throwing a no turbo boots code and the truck has just about no power pulling hills or a load on a trailor dose urs do this all i can get out of the ford dealers is that its a pressure problem. when you unhook the icp the idle problem goes away but the no power problem dosent any info would be awsome thanks |
dont give up, some real good techs here. I am sure they will chime in.
Good description of the issue too. |
Man you have been chasing rabbits and spending $$$$$. STOP!!! Take a deep breath and have the truck scanned for codes, these trucks are not OBDII compliant so the FREE scan at AZ won't work. It sounds like maybe the EBPV is closing on you when it shouldn't be. Pull the EBPS on the front, left side of the engine, it is just above the CPS and sits on a metal tube, clean the bottom of the sensor and the metal tube of all carbon deposits with brake cleaner. But don't go buy any more parts until you have the codes read.
I have done the ebpv thing where you take it off and clean it i didnt spray break cleaner down in it but i did take that tube off and it wasnt very dirty at all might take it off again and spay some cleaner down in it i blew threw the tube and it was clear
as far as the clodes its throwing a low/no turbo boost code they told me at the ford dealer that the screens in my tank were clogged thats why it was running like this so after they told me 700 to drop the tank i brought it back home and did it myself while i had the tank dropped i did the intank fuel mods the screens were very dirty but when i got it back together it didnt do anything so i took it back to them and they told me all they new was that it was a pressure problem there quick to take ur money but give you very little info on the truck i do know that the low turbo boost code was one of them if that will help at all |
Took my truck to ford today and they said
the number 1 and 8 injector were missing and that when they took the truck out for a drive when they jammed on the throttle the hpop was only putting out 1800 psi and they said it was suppose to be a min of 2800psi so where do i start new hpop or ipr or injector the hpop that i have on it now it just over a year old and the ipr came off a truck with 63000 miles i guess i could have gotten a bad hpop just dont know where to start now any info |
