Heating up
Towed to Daytona this weekend and had a slight problem on the way back.
If I would run about 70 the engine temp would slowly creep up. Getting to the red at one point. If I would slow to 60 the temp would come straight back down. This was a drop of about 300 RPM. Egt was 8-900, trans was 180, boost 6-12psi. Any suggestions? Water pump is about 10K old. I was thinking a clogged radiator. Neill |
how bout a stuck thermo-
Hope so. Strange thing was it would heat up at 70 and cool right back off at 60. (300RPM difference)
Can a stat be partially closed therefore blocking some but not all coolant flow? Neill |
BUMP.
Towed this past weekend on the stock setting and still same problem. Neill |
