NEED SOME HELP PLEASE!!
03' 7.3L RUNNING SUPERCHIP PROGRAMMER
I'm located in Ky. where it's been cold. And my truck has been running fine! Today it's 38 degrees, I cranked my truck today and it ran fine. I drove it about 2 miles when I took off from a red light it fell on its face and died! It turns over fine actually to good! After about 10 mins. it crank once,but when I put it in gear it died! And I finally had to call a wrecker! $60.00 to go two miles! I changed the CPS as soon as I got home, but still no crank! I put the progammer on it and I pulled these codes.. p1280, po237, po733, po478, p1212, p1211. I had the 5.9K mod on it and the pigtail that tricks the MAP sensor but I removed it when it wouldn't start! And it still doesn't start! It doesn't even try to crank no smoke no nothing! Anyone know what might be causing it not to crank? thanks for your help! |
You need to get a scanner in that bad boy and check out your ICP pressure.
it needs to me min of 500psi to start.. Is your fuel pump running? So many codes seems like a harness came loose.. Last edited by street_legal?; 12-18-2009 at 05:07 PM. |
Not even a month ago I had it in the ford shop and everything checked out good except the IPR valve. I changed that out and then no codes except the ones that it normally throws because of my programmer. I do have a spare icp sensor, and I'm not sure about the fuel pump running. I was on my way to work and I'm at work now so I haven't had time to even check the fuses or anything.
