New truck wont start - Ford Powerstroke Diesel Forum
Old 12-16-2009, 02:18 PM
Hi I just bought a 2001 F350 it has 310k miles on it. When i bought it the guy said that it ran but missed a little. So he had a mechanic pull the glow plugs to have a compression test done and the mechanic broke the glow plugs. But now its not getting fuel when you crank it over. What should i look for? I've checked the fuses and they all seem to be good so is there something else i need to check. Maybe something didnt get plugged in. idk
Old 12-16-2009, 02:29 PM
there's a million and one things to check......
is the SES/CEL on? if so, are you able to pull codes at all?
Are the harnesses at the valve cover gaskets all connected, good, and not burned or melted? check the exterior as well as under the valve cover harneses...
Did the truck run after the mechanic broke the glow plugs and later it wouldn't start? or has it not started since the mechanic worked on it? (I've seen some not very good mechanics hook up the injector harneses wrong, without clips, backwards, etc.)
Pull your fuel bowl cover and verify it has fuel in it, if you are able test your fuel pressure at the schrader valve on the fuel bowl
are you getting any smoke during cranking? if so what color, blue, grey, white, etc? does it smell like raw fuel?
Does the wait to start light come on?
how did you verify the injectors are not getting fuel?
Old 12-16-2009, 03:35 PM
wiring harness at the valve cover is connected and good. It has not ran since it went to the mechanics. I did'nt see any smoke coming out. But i was not looking for any. wait to start light comes on. I'm not positive that its not getting fuel but I'm pretty sure.
Old 12-17-2009, 05:54 AM
Powerstroke Junkie
Open the drain valve on the back of the fuel filter bowl, yellow lever, turn key on, the drain line stops about 1/2 way down the front of the engine slighty to the pass side, you may want to add a hose to it and run it into a pop bottle because the fuel should come out in a good strong stream. If no fuel, check fuses with multi meter, if all are good I would be looking at a bad fuel pump. Did you break apart the the UVC connection at the vc and look for burnt or loose pins?
Old 12-18-2009, 02:48 PM
Yep fuel is coming out so it must be something not plugged in or somethings burnt. I'm hoping to have it running soon because i really need it for firewood.
Old 01-22-2010, 02:09 PM
so ive final got to start working on it again and i put oil into the high pressure oil pump reservoir and after cranking for awhile it started puffing fuel out the tail pipe but its leaking oil out of the reservoir pretty fast so i bought a gasket and i hope that will fix it hoping that this will fix it
