AE not finding my 03 E-350 - Ford Powerstroke Diesel Forum
Old 12-13-2009, 02:43 AM
I bought the AE software with the Ford bundle a couple of weeks ago because I was having no start issues with two 7.3L's. I found that it is not compatible with the 1995 1/2 F-250 I wanted to use it on. Now I have plugged it into my 03 E-350 and it won't even acknowledge that the plug is connected. Anyone know what might be the problem? The software does work well on my 01 F-250 7.3L.
thanks,
Patrick in Chicago Land
Old 12-16-2009, 07:13 AM
Powerstroke Junkie
Did you follow the PSD settings recommended on the ITP website? Might want to do that.
Old 12-16-2009, 07:23 AM
Need to configure communications, go to vehicle drop down menu, comm. configuration, vehicle interface type: j1850 pwm. initialization type: non-obdII only. boom, done! also if the 03 is a 6.0, it uses CAN high speed comm. need to configure from same vehicle menu, use auto detect and obdII compliant, when comm is established it will promp you to enter a vehicle system, choose 6.0 powerstroke.
