7.3 fuel leak - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-05-2009, 10:14 AM Thread Starter
7.3 fuel leak
There is a tube coming off the back of the fuel filter housing, it is dripping a little bit of fuel, trying to fing out what would cause this problem. Thanks Crozz
Crozz is offline
post #2 of 3 Old 12-05-2009, 10:16 AM
ADMIN AND TECH
SCUFFY828's Avatar
water seperator drain valve is usually what is leaking , get you a new drain valve , they sell the o-rings to replace those but ive seen alot of the valves bad as well, fairly common problem with a 7.3
ITS STOCK
SCUFFY828 is offline
post #3 of 3 Old 12-05-2009, 11:04 AM
HOUTX01X's Avatar
Quoted: 4 Post(s)
a quick search all the info you need plus more....
search button is your friend
http://www.dieselorings.com/docs/fueldrain.pdf
Leaking Fuel 2000 7.3 HELP!!!
slow dripping fuel leak help (pics)
Separator Valve Rebuild
'11 F250 KR
XRT Pro, H&S SX-E turbo kit, NoLimit intake/intercooler
OUO bars/blocks
Ø-EGR,CCV,1993pf
Leveled w/ 35 atII
HOUTX01X is offline
