gouges/nicks inside turbo manifold?? - Ford Powerstroke Diesel Forum
Old 03-21-2007, 10:27 PM
i have a 1999.5 f250 7.3 PSD.
i recently changed the clamp connecting the intercooler duct to the turbo manifold and noticed there are a few big gouges and nick in the turbo manifold. does this mean anything???? any problems, etc. occuring?
also, does a 2001 7.3 turbocharger fit in my 1999.5, 7.3 PSD? i have an extra one and it doesnt have any gouges or scratches in the manifold inlet. just in case i should replace the one on my 99.
ANY HELP IS GREATLY APPRECIATED. THANKS
Old 03-22-2007, 04:09 AM
Send a message via AIM to purduefarmboy460
bump bump bump
Old 03-22-2007, 04:14 AM
HardLuck Case of the Year
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
Turbo Manifold???
Are you refering to the Compressor Housing and the actual Compressor Wheel??? If you have chips and scratches on the Compressor wheel/housing (inside) you have some filtering problems. Get a better Air Filter! I personnally wouldn't put a post-99.5 turbo anything on a 99.5. The 99.5-03 7.3L turbos are getting replaced by people with the pre-99.5 compressor wheels. (Surge is a PITA!)
I hope I answered your question. Sorry if I missed the point a little!
Old 03-22-2007, 04:25 AM
Desert Shield/Storm Vet
Yeah ditty is correct if you do any kind of mods such as tuning you will probobly run into surge with your turbo! The whicked wheel is one way to correct or help alleviate the problem.Yes the 99.5 to 2003 turbo is the same so you can swap them out.
Old 03-22-2007, 06:12 PM
im not referring to the turbo compressor, im referreing to the manifold that is bolted to the compressor, it has the 2 intercooler duct pipes connected to the manifold that is bolted to the turbo itself..the nicks are in the manifold...thanks for the responses..
Old 03-22-2007, 06:15 PM
im reffering to the manifold, not the compressor wheel. the nicks are in the manifold which is located behind the engine cover and bolted to the turbo. it has the 2 intercooler pipes connected to it.
thanks for the advice.....so should the manifold be ok if it has nicks in it?
Old 03-22-2007, 06:38 PM
Are you talking about the y-pipe? Hmm yeah I dont know I believe that is a cast piece. Could be from the casting at the factory. That is interchangeable also with 99.5 to 2003 psd's
Old 03-22-2007, 08:05 PM
yeah it looks like its cast, but im not sure if it supposed to have gouges like it has.....??? has anyone else taken a look in their manifold??
Old 03-23-2007, 12:47 PM
Send a message via ICQ to Lord Tauk Send a message via AIM to Lord Tauk
Take a picture if you can?
As everyone else says, it is a casted part; so who knows what happened with the sand or whatever when your part was being cast? They're all going to be a little different than one another as far as surface finish is concerned because of the casting process.
