cps problems - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-19-2007, 04:36 PM Thread Starter
gregor's Avatar
cps problems
I just put a new cps in my truck about two weeks ago and last night it started acting up again. I pulled the codes and they are for the cps. I called Napa because that is where I got it from and they said that they will not refund my money because it has been "used". When I replaced it the first time I had no problems getting the old one out but this time I can't seem to get it out I allready went to an International dealer and got a new one to put in. I was wondering if there are any tricks to getting the old one out? I need to get this changed as soon as possible and to make it worse the high temps here are only about 5 or so, after about ten minutes of messing with these I have to go inside to warm up. Any help would be appreciated.
Also one more thing is it possible that they sold me the wrong one?
2006 F-150 Supercrew
Cold air intake
Dual exhaust
Alpine stereo
[/QUOTE]
gregor is offline
post #2 of 11 Old 03-19-2007, 04:39 PM
Desert Shield/Storm Vet
vitalidle's Avatar
I have read where the nappa ones don't hold up. I have never changed one yet, so I don't have any tricks up my sleeve to share with ya!
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #3 of 11 Old 03-19-2007, 04:42 PM
sldghamr's Avatar
your CPS is one of the things that is SO IMPORTANT that you should get it only from the dealer cuz chances are the dealer won't give you the wrong part. years ago i bought a thermostat from Kragens and then went to a mechanic to have it changed out. the mechanic said that if i had use the kragen one, i would've lost my engine. i now go to the dealer to get that particular item.
as to how to change out this one, you got me.
if you see a light at the end of the tunnel, it's probably just a photon torpedo
sldghamr is offline
post #4 of 11 Old 03-19-2007, 04:45 PM Thread Starter
gregor's Avatar
I have read that the internatial ones are just as good if not better than the ones from Ford, and it was cheaper so I figured that I would give it a try.
Cold air intake
Dual exhaust
Alpine stereo
[/QUOTE]
gregor is offline
post #5 of 11 Old 03-19-2007, 05:36 PM Thread Starter
gregor's Avatar
I could really use some help here, I got to be at work in about two hours and that is where the truck is at now, hopefully I can have fixed by the morning.
Cold air intake
Dual exhaust
Alpine stereo
[/QUOTE]
gregor is offline
post #6 of 11 Old 03-20-2007, 12:11 PM Thread Starter
gregor's Avatar
bump.......
Cold air intake
Dual exhaust
Alpine stereo
[/QUOTE]
gregor is offline
post #7 of 11 Old 03-20-2007, 05:00 PM
tap and wiggle...
did you get it out?
I got my spare from ebay for 50 bucks, original ford part, keep it in the glovebox.
02 F350 PSD Lariat CC
mostly stock except the bb turbo and stage 1's...
...and of course the supporting mod's
Dagnuten is offline
post #8 of 11 Old 03-20-2007, 06:50 PM
Cartsrcool's Avatar
I had some trouble with mine too. Just try twisting it untill you can get it far enough out to stick a screwdriver behind it and work from side to side. Maybe a little penatrant around it while you try to turn it. Hope you get it ! Stay warm! Later
Craig
Cartsrcool is offline
post #9 of 11 Old 03-20-2007, 06:52 PM
Jon
Guest
Posts: n/a
Quoted: Post(s)
I
take a long flat head screw driver and pry under the metal timing bracket and it pops right out. Its just the new oring holding you up.
post #10 of 11 Old 03-21-2007, 12:11 AM Thread Starter
gregor's Avatar
I finally got it changed today. When I was trying to pry it out the metal bracket broke, so I ended up putting vice grips on the front and was able to pull it sideways enough toget a screwdriver in there. Thanks for all the help, this is the second time I have changed it (first time it came out with no problem) and hopefully it will be the last.
Cold air intake
Dual exhaust
Alpine stereo
[/QUOTE]
gregor is offline
