Why? Why? Why?
Does anyone know why the CPS's in these trucks are such peices of junk? I just had mine replaced about 2 months ago. Classic symptoms and codes pulled pointed to a CPS. Changed it out, new one had no problems for about 3 weeks and then periodically started acting up. Seems like mostly when it is raining or very wet roads. You know, engine chugging, cutting out at low RPMs. Whats the deal with these things?
when was your last oil change, what is your oil level, have you changed the fuel filter, have you drained the fuel water seperator yet. I would be checking these things out before you go run out and buy a new cps again. As low oil level, dirty oil, old oil, clogged fuel filter, water in the fuel can all cause the syptoms of a bad cps. You may also want to check the under valve cover wiring harness might have a bad connection there causing these problems as well.
These
trucks also are known to have water getting into the idm connector and causing problems like your describing. What codes did it set then and what codes is it setting now? VERY rarely will a cam sensor go bad as soon as your new one did? Is it a Ford sensor?
Aftermarket
cps have been known for repeated failures. The Idm is in the drivers side fender well. You have to pull the inner fender back a bit to get up in there. If you look around you will see everyone saying get a Ford or IH sensor. There is a reason for that.
If indeed I have another bad CPS I'll go to an International dealer and get my next one. |
