strange noise when steering...braking - Ford Powerstroke Diesel Forum
Old 03-17-2007, 02:15 PM
Hey guys.. I have an 02 F250 Crew Cab 4x4 7.3.... my truck is making a strange growling noise (from the engine compartment) when I apply the breaks and really makes it when I turn the wheel sitting still. It is almost as if my power steering isnt working at all sometimes... the wheel can be hard to turn at times while sitting still. I checked all the fluids and all are filled properly. The truck makes it also when it is idling... seems to get better when I rev up the engine. Any ideas??? Any suggestions would be great!
Old 03-18-2007, 08:15 AM
ADMIN AND TECH
power steering pump bad
Old 03-18-2007, 11:53 AM
duct tape & zip ties
Replace powersteering pump with new one. It is not hard to do, but you will need to drain the coolant level a little bit as the upper radiator hose needs to be removed in order to do the job.
