top rear oil leak - Ford Powerstroke Diesel Forum
Old 11-12-2009, 11:56 AM
O.I.F. Combat Vet 11B
top rear oil leak
I have been trying for 3 months to get rid of the oil dripping on my driveway. I know it is coming from the top rear of the motor and have replaced the turbo and ped orings with no luck of it stopping. I can wipe off oil from starter and trans and go for a drive and be there again ready to drip. It may drip 1 maybe 2 drops a night so I know it is a very small leak where ever it is. Oh and the ebv rod has been plugged too. I know I have some blow by and getting some from the boots but I just don't think that is where I am having this problem. I plan on getting a catchcan for it one of these days. I was just curious if anyone knows of any other o rings or anthing where oil can leak to cause this. Not really a big problem but makes the driveway look like crap.
Old 11-12-2009, 11:59 AM
Here's an excellent video on chasing down leaks on the 7.3:
Longevity Module; Identifying & Fixing Leaks
Old 11-12-2009, 12:13 PM
valve cover?
Old 11-12-2009, 12:15 PM
Im having the same problem
Old 11-12-2009, 12:26 PM
I tell you, it would not be hard to ruin a turbo O-ring while trying to stick that thing in there. I just installed mine cause of the up pipe exhaust leaks. Its a pain, and tight in there.
Old 11-12-2009, 12:59 PM
Let's go B's!!!!
Feedback Score: 5 reviews
You positive it's coming from the rear? Is there oil in the front part of the valley? If there is, it is the HPOP o-rings most likely.
Old 11-12-2009, 01:14 PM
if he changed the ped orings i would bet its the hpop seal mine leaked forever and thats what it is look in the valley there will be a small puddle toward the front of the engine the oil is just running back
Old 11-12-2009, 02:33 PM
nope, dry in the front. only wet under the turbo. It more very well be just comeing from my boots.
Old 11-12-2009, 02:36 PM
Originally Posted by melmount View Post
valve cover?
not the valve covers, they are dry.
Old 11-12-2009, 02:46 PM
Same problem here.......just enough of a leak to irritate you
