2002 HPOP
I have a 2002 ford f-350 it has been leaking oil pretty bad. It has been coming out from between the bell housing guard and the block. I took it to the dealer to get a repair estimate and they said the oil was coming from the HPOP out of the so called irremovable bolt on the bottom side of the pump out of sight. I can see the oil gathered on the intake under the pump. I am sure it is not coming from any of the oil lines off the pump. what is the best method of repair new, reman or aftermarket? I will be upgrading the turbo, injectors and most likely nitrous or propane would it be better to go to aftermarket and if so which one? I just purchased the truck not to long ago so the mods are down the road for now I am trying to spend less than $1000 I have recieved prices on a reman for 400 a new bosch for 550 and repairing the existing one for less than a 100 whats the best option I dont know???Is the R&R simple??? are there any special tools needed???
If you going to upgrade your injectors down the road then it wouldn't be a bad idea to upgrade your HPOP while it's out. If your looking for cheap check out the adrenaline HPOP, if your looking for big power then check out the terminator twin pump or the stealth pump. The adrenaline is around 600, the terminator is about 3000 and the stealth is about 1500 for the stage 1 (3500 for the stage 3). I like the stealth pump because it is upgradeable so if you don't need big oil now you get the stage one, but if you go to big injectors then you can upgrade it to a stge 2 or 3. FYI I got these prices by doing a quick google on each, you can probably get them cheaper elsewhere.
As for removing the HPOP it is pritty straight forward, you have to take off the fuel bowl, the intake y-pipe, and the oil resivor. If you want more info on removing the pump say so, I just gave a quick overview. The only tool you will "need" is an oil line removal tool. It's a 1/8 piece of flat steel with a notch cut in one end, and it pushes back a rubber fitting that holds the two lines to the pump, you could probably make your own or just carefully use a screwdriver. Like I said it's not to hard, It will take a novice 6-8 hours tho. |
Thanks for the help Cory |
The y-pipe is pritty straight forward, theirs 4 fuel lines you will have to take off the bowl and it has two bolts that go through to oil resivor that hold it on. Next is the oil resivor, it has 5 bolts that hold it down, you'll have to get a new gasket for here. Now you'll have a big hole in your front cover that has the drive gear for your HPOP, so don't drop anyting down the front cover or you'll have big problems, so stick a few rags in it. Next you have to pull the upper hose that goes up, across the top of the engine, out of the water pump.
Now, on the front cover their is a flat cap that has two 8mm bolts in it, and also has a sensor that is mounted to it that has a pipe attached that goes down to the right exhaust manifold. Take the pipe off the sensor first before removing the plate(you don't have to remove the entire pipe, only take it off the sensor). This will alow you to acess the bolt that holds the drive gear to the pump. Remove the bolt (carefull not to drop it down the front cover) and then remove the gear (you won't need a puller). Then remove the two lines off the HPOP, then remove the two bolts that hold in the pump the remove the pump. As for if it's woth getting the line release tool or not, its up to you, I had one when i took one off but after I saw what it was, (after we were waiting for all weekend) you probably could do it with a screwdriver but IDK. Thier only like a few $ so it migh be worth getting one to be safe. |
thanks for the help Cory |
No, the HPOP is gear driven. No idea what the chain is for?
Someone said it might have been the transfercase I hope there isnt anything else wrong with this truck I am going to try to research the part no. on the box
Thanks Cory Oh by the way I ordered the adrenaline pump I hope its as good as I hear |
