"Thunk" from under the floorboard when braking? - Ford Powerstroke Diesel Forum
Old 03-14-2007, 07:25 PM
I'm noticing that almost every time I break I can hear (and feel) a "thunk" as if something is shifting or flexing underneath my truck. Could this be a sign of failing ball joints or other worn front suspension components?
Old 03-15-2007, 05:10 AM
holy crap, i have that 'thunk' whenever i start out from a light. at first i thought it was a bad motor mount. but its not. now im thinkin tanny mount, what the heck else could it be? i wonder if its the same thing... if i start out real nice and slow it dont do it... does yours thump and u can feel it in your seat? where does it feel like its coming from?
Old 03-15-2007, 05:16 AM
Fishing Fanatic
I get a thunk/pop when I turn the wheel at slow speeds sometimes, but I have jacked it up, shook the wheel up and down, side to side, with NO play, so I am still trying to figure that one out!!
Old 03-15-2007, 05:40 AM
i have the same thump when appling the brakes sometimes. I am going with ball joints ....if i crawl under i see fresh signs of bright rust washing out of the joint area like something is moving. oh boy 1 more thing to do .
Old 03-15-2007, 05:48 AM
Almostdunfukinwidit
just cured that problem on mine it was ball joints and sway bar bushings
Old 03-15-2007, 05:51 AM
I don't know nuttin....
Check those balls and also check your brakes to make sure everything is nice and snug
Yours sounds like rear end slack...maybe a bad U joint also. Get any vibration at highway speed?
Looks like I have a whole lot of summer projects to work on...Bad GEM, swaybar bushings/ball joints, and I just realized I have an oil leak! Actually I get the "thunk" from the rear when taking off sometimes too. It also happens when I'm cruising along at say 40-50 mph and I apply throttle to pass. Still sound like a bad rear universal?
Old 03-15-2007, 05:53 AM
Almostdunfukinwidit
didnt you just buy that thing
Old 03-15-2007, 05:56 AM
Almostdunfukinwidit
yeah i agree with clay on that one bad u joint as well. i would get that done asap driveshaft rebuilds arent cheap
Old 03-15-2007, 06:02 AM
I had a thump when I braked. Turns out one of the bolts holdin the caliper braket on had fallen out.
