99 f350 auto
I got a kit from tugger to change the springs in the valve body. I dropped the pan took off both valve body's, the solenoid pack, and the separator plate to check the feed bolts while it was apart. I check the location of the check balls many times online I'm almost positive there right. Then I put the springs in paying attention to the instructions carefully. I also did a bypass valve delete. I put everything back together, filled the fluid. Started the truck shifted from P to 1 many times checked the fluid got in it put it in reverse and it wouldn't move neither would any other gears. I'm hoping someone can tell me if they think it's the valve body or the check balls before i tear it open again.
