Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems
Old 10-26-2009, 01:41 PM
geoff thomas geoff thomas is offline
Send a message via MSN to geoff thomas
Angry Problems problems problems
I went up the road to get take out with no issues then on the way back the power steering went but only when i turn right, left turn is fine when i parked the truck it was flexing the smallest amount ever driver side front up, dunno if that is of any relevance. Please help
Old 10-26-2009, 02:20 PM
To the top please help i am pulling my hair out!!!
Old 10-26-2009, 02:26 PM
rankroddin250 rankroddin250 is offline
can u see any thing broke?
Old 10-26-2009, 02:56 PM
not that i can see but it is dark here in England will check tomorrow morning, could the pump just give up without warning?
Old 10-26-2009, 03:37 PM
forddieseldoctor forddieseldoctor is offline
Powerstroke Techie
If it works one way and not the other it's usually a steering gear. Raise the front tires and remove the drag link from the pitman arm and see if the wheels move freely side to side.
Old 10-26-2009, 03:40 PM
adfields adfields is offline
Not the pump if it works one way, it's the valve in the steering box. You need a new or re-con gear box, and if it's right side drive I'm glad you don't have my Visa card!!
Old 10-27-2009, 01:37 AM
rightside drive? whats that?
Old 10-27-2009, 11:44 AM
The side the driver sits on in the UK and Down Under. Not sure but I bet the steering gear box is a special casting if it's bolted on the right side frame rail.
Old 10-27-2009, 01:05 PM
gtspowerstroke gtspowerstroke is offline
Yeah it sounds like it's the steering box but make sure it isn't a hard part like a ball joint or bound U-joint or something. Do as forddieseldoctor said and remove the drag link from the pitman arm and make sure you have smooth operation of the balljoints ect.
BTW nice name. That's mine too!
Old 10-27-2009, 01:07 PM
Adfields looking at his picture it looks like it is the standard left hand drive.
