Brake problem
Hey guys, I have a problem with my ex that has me concerned. Yesterday I was hauling a car trailer with a small-medium size car on it. Hauled it about 30-40 minutes away on roads that average speed was 50. Well, I started slowing down for a turn, and the pedal went to the floor, pumped again, still nothing, third pump I started feeling some resistance, but still no where near what it should be.
My game plan now is new rotors and pads all the way around, and fresh brake fluid. Going to suck all the old fluid out with a power bleeder on all 4 corners. Anything else I should do, or look at? I'm about to leave for a road trip, so I want all my concerns addressed before I leave. The part that has me concerned, is that I looked at the pads, and I have bare minimum 40% of the pad left all the way around, and my brake fluid is about half full. My thoughts is that it's old OEM fluid, and is overdue for a change. With lower viscosity due to age, I may have boiled the fluid in a caliper or two. Would you guys agree? If so, am I taking the right action? Anything else you'd look into? Is it a sign that the master is going bad? Or something else? |
Need a little more info.
Is the brake warning light on? Do you have a "hard" pedal, that is the vehicle will stop but fees like no power brakes? Do you hear a ticking noise from the left front of the engine? All of the above are symptons of the vaccuum pump going bad. I had to replaced my vaccuum pump about every 150,000 miles and every time it had one of the above symptoms. Jim |
wonder if you have air in the lines at all. thats a scary feeling when your brake pedal does that. hopefully you find the problem.
No brake warning light. No hard pedal, she just went soft to the floor. Ever since, brakes have been fine. No ticking noise. If your asking if I can hear the vac pump when I start it, yes I can. |
Well for one this truck uses a hydro booster. So replacing a vacuum pump would do nothing for his brakes.
How is your powersteering, does it work good. Is it low in fluid. Do you see any leaks of brake fluid or powersteering fluid. With the pedal going to the floor and needing to be pumped up. That tells me you are loosing pressure in your brake system. So I would be looking for leaking brake fluid. Being your pads are worn equally I don't think it is at your brake caliper. I would look at your master cylinder as well. |
![]() ![]() Had flashbacks of that night when it happened in the ex, and I'm doing everything I can on Tuesday to correct it. No way in hell is that going to happen again. |
I think I'm having this problem now. I woke up this morning, started my truck, and noticed the ! BRAKE light came on in the dash, and my pedal went straight to the floor. If I floor the brake pedal, the truck will slow down and stop, but there's very little to no resistance when pressing on it. I didn't notice a ticking noise, but the other symptoms match. |
If your pedal wen to the floor you have a problem in the Master Cylinder or Hydroboost system. If your PS is ok I would replace the master cylinder. Changing the pads and fluid ain't going to help this problem!!! Although the fluid should be flushed every two years and brake fluid collects water and the water will settle at the calipers. While you are at it I would also lube the slide pins on the calipers, something that most owners fail to do until they are frozen. This isn't part of your problem but should be done.
On another note, your vent only blowing out the defrost is a sign of a vacuum leak, you probably don't have 4x4 unless you manually lock the hubs either. The most common place is at the back of each hub where the vacuum line slips on to the nipple, the hose gets cracked or split and won't hold vacuum, cut off the damaged area and push back onto the nipple. Another place is the pass footwell there is a vacuum line that can get kicked loose. You have some problems that need to be addressed. PM me with any ? |
