CPS question...nothing critical - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-07-2007, 02:41 PM Thread Starter
Smile CPS question...nothing critical
okie dokie...regarding hooing up a tach to a diesel...specifically a 7.3. I picked up a little gizzmo at Summit Racing the other day..a GMR induction pickup. connect it to either the #1 injector wire (OK if your tack has a "1 cyl operation mode) OR the main 12V feed to the injector harness (which at this point I have no clue as to where THAT is) However, and here's my question. Does the CPS read only 1 "hit" per rev telling the pcm (or whatever) that 1 particular cly is ready to fire and then the pcm has to figure the rest out on itsa own...OR does the CPS read 8 seperate "hits" ie for each cyl per each revolution? I'm asking this because if the CPS actually picks up and sends a seperate signal/pulse for each cyl, I could, a lot easier, simply attach the GMR pickup to a CPS lead and Viola, I have my tach feed. Sounds simple..probably not..lol. Any knowledgable techs, geniuses, shadetree mechanics, spiritual Gurus or store room clerks out there have any ideas/info?
Thanks.
howardtm is offline
post #2 of 2 Old 03-07-2007, 03:07 PM
Powerstroke Techie
djsdiesel's Avatar
I am almost positive it only picks up one per revolution. I would say the easiest way to get a tach on your powerstroke is to buy a AIC there is a link to one on ebay if that link doesnt work here is the item number 280089193317. Or I have seen a tach that picks up rpm off of the alternator. But the AIC does multiple functions and is well worth a couple hundred bucks. From ford they are like $800.
99.5 F-250 PSD AT 4x4, 4in lift, 37 13.5 18 Pro comp Extreme A/T's, S&B Intake, GTP38R, DP Tuner custom programs (140 Agg., 120 sled pull, 80 tow and 60 tow), Rosewood DIY stage 2 injectors, BTS Trans, 5in exhaust no muffler, 6 oh intercooler, Ford AIC, EBPV delete, Foil delete, T/C lock up mod, Pusher Fuel Pump, Three Chime train Horns
djsdiesel is offline
