Arrrgh, need some help
I have a '02 f350 I purchased from my neighbor 6 months ago. It ran great 2 weeks ago. 3 weeks ago I had the CPS replaced at ford, when I picked it up it seem to idle rougher and seem to lack the power it had when I dropped it off in the morning. It had a #4, #5, #8 contribution failure codes stored, so I replaced the CPS with a "black" CPS from international. It seem to idle better but #4 still fails the contribution test and rotational velosity bounces between 0-18% so I'm thinking # 4 injector is going bad, # 5 will bounce up to 8-10% but they are next to each other in the firing order so I'm thinking its #4 affecting #5. So I got a new injector, but before i had a chance to replace it I lost oil pressure on the factory gauge, I replaced the sending unit on top of HPOP res. still no pressure. When the oil pressure gauge started acting up the trans gauge started acting weird also, when I start the truck it comes up to the bottom of the scale and withing 30 seconds it is 3/4 up the scale. I have a Genisys scanner, trans temp showed 59* at the bottom of the scale and when it went to 3/4 the fluid was only 68*. The oil level stays the same in the HPOP res. about 1/4-1/2" below the filler plug after starting and after sitting for 10 hours. I tried changing the oil, I cut the filter open and looked for any bearing material, it was clean. I changed the low pressure oil pump, it had more play in the housing then the new one, but still not enough to move the gauge, there were no marks on the timing cover, where it may have been grinding the cover and losing pressure. The guy i bought it from changed the oil every 4000 miles with rotella and a wix filter (has the recipts to prove it) ICP is 550-625 at idle and will climb to over 1500 psi just reving in neutral. I tried adding a quart of oil and jacking the rear of the truck up, no change in pressure. Also the turbo makes a "gurgling" sound when you let off the gas, almost like wastegate is no opening fast enough to vent pressure and its rattling the turbo. The turbo shaft spins free and there is no movement in the shaft. I know it need a # 4 injector based on rotational velostiy readings, but I want/need to fix the oil pressure problem first. So far I have checked/changed
CPS with international part
Oil pressure sending unit for the gauge
LP oil pump, and check cover for wear
Added a quart of oil and jacked the rear of the truck
Oil level in HPOP res. hot/cold
verified ICP pressure idling and reving
Do the clusters in these trucks go bad? Any known electrical issues with oil pressure/trans temp wiring harness? Does the wiring go directly to the cluster or does it go through a module? I have alot of automotive experiance but this is my first diesel and first Ford, so I'm going over the basics but need a little more insight from a pro, any help/ideas would be appriciated, thanks
Rob
Sorry for the long post, just tring to give you as much info as possible, thanks
