Truck is leaking oil AGAIN!!
Truck was laking oil a couple weeks back. It was the HPOP lines under the fule bowl. They needed o-rings. Now it is leaking oil again but from somewhere else. I pull the intake off the turbo and there was oil in the valley but could not see where it was comming from. I even ideled it for about 5 min looking for the oil, nthing. Now it is leaking less but for no reason?
Where to look next? |
ANy ideas?
turbo pedestal o-ring ,valve covers, or dog house probably turbo ped if it's not hpop oring.
Are you sure it is oil and not fuel could be o-ring's in fuel bowl drain valve that fills up valley also. low sulfer diesel doesn't do anything good for our orings. |
Justput new gaskets on the fuel bowl.
