Many Problems
I have many problems with my early 99.
When going 55+ there is a bad vibration when throttling slightly. it gets worse when im not throttling it. When i get up around 80, it gets VERY bad, it doesn't matter how i throttle it it vibrates BAD when the wheel is turned all the way over, and drive slowly, there is a bump... bump... bump... its pretty big. the Steering wheel jerks *sometimes* when i brake. it also does it sometimes when i accelerate. I can almost say for sure that a u-joint is bad because when i put it in reverse, or drive there is a big CLUNK. reverse also takes around 2-3 seconds to shift. i think i need the trans fluid changed. ALSO- it also clunks when i accelerate and let off the throttle, again, i think its a bad u-joint. i tried checking for something, but i dont know what im looking for. what do you think is wrong? Last edited by ZombieWeinerDog; 10-07-2009 at 11:38 AM. |
I would start with jacking up the front end and checking everything out. Grab the wheels and check the wheel bearings and ball joints... then just see if anything is loose.
I agree. Jack it up and look around. You may be right about the ujoint. Any steering stabilizers? Do you maintain yourself or have it done? Is everything lubed?
Sounds like you may have one or many springs broken. The clicking when you turn sounds like it could be a half shaft or u joint.
You definetly have a bad u-joint. I've replaced 4 sets in my 2003 van. Take it out on thr highway and set you cruise control and start down a hill. You will hear the cruise control "bumping" the u-joint trying to keep up with the speed.
Good luck, Jim |
