Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems
Old 10-04-2009, 05:28 PM
UnlimitedLove UnlimitedLove is offline
Cruise Control Stopped working . . .
Cruise Control stopped working. Anyone have any knowledge on where I should start looking?
Thank!!
Old 10-06-2009, 09:15 PM
BlackPearl03 BlackPearl03 is offline
on my 03 there is a electrical connector right below the hydro boost. If it comes unplugged then your cruise wont work. You might start there.
Old 10-10-2009, 09:44 AM
Toads Toads is offline
Mine did this once. It was because my emergency brake pedal was bumped just a little. Make sure your e-brake is totally disengaged
Old 10-21-2009, 07:20 PM
Thanks guys. I'll try both of those ideas.
Old 10-21-2009, 07:31 PM
smitty16s smitty16s is offline
Location: Little Rock Air Force Base,Arkansas and North Augusta,South Carolina
i would take it in to get the recall done first, that may be your problem
Old 10-21-2009, 07:34 PM
Had that done this weekend when the oil was changed. . . and still no Cruise Control.
Old 10-21-2009, 08:09 PM
LOOSEWHEEL LOOSEWHEEL is offline
You have a 6spd so I would check the CPP - Clutch Pedal Position switch.
