Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems
Old 08-01-2009, 06:59 AM
chieftkp chieftkp is offline
2001 starting problem
The truck has 133k on it and the engine really hasn't given me many troubles until now. When the truck sits for a few days it's nearly impossible to start. If I run it everyday, it's perfect. Dealership said it was a problem with the high pressure oil system and they are looking for $1k to fix. I talked to another shop and they offered to do the work for $800. I was told this job is mostly labor. Does this price sound right? At the dealership they never have me talk to the tech its always some stupid service "advisor" or "manager" never the guy who knows really what is going on. The truck does not leak oil so it does not seem like the common o-ring problem that I am reading about. When I talked to the other shop the guy said they have done this job a bunch of times.... Anyone have any tips?
Old 08-01-2009, 07:18 AM
ajpu1983 ajpu1983 is offline
There's a lot to the ICP system. What O-rings are they talking about? Injector?
Old 08-01-2009, 07:33 AM
Sorry for lack of info. I found the service slip and I went through it and they have all sorts of stuff on it with some codes, but in the end it says: "Vehicle needs injector reseal kit performed" They want $980 for this job. Does this sound right?
Old 08-01-2009, 10:28 AM
That job is 7 hours book time plus the O-ring kits. So if their labor is as high as I think it is that sounds about right. It would be about $750 at my shop but we're an independant shop so...
Old 08-01-2009, 11:59 AM
Thanks for the info. Sounds like I will have to spend the cash.
Old 08-01-2009, 12:03 PM
Dave Dave is online now
Obama sucks
If the problem is what I think it is. Injector O rings arent gonna fix it. Whats ICP when cranking cold? If thats where it belongs. It may need injectors
Old 08-02-2009, 06:42 PM
OK Dave, I have the estimate and some codes. P0340-CMP sensor circuit malfunction, P1211- ICP not controllable? Pressure above/below desired, P1212- ICP voltage not at expected level.
They checked the glowplugs and the check valve in the fuel filter housing assembly it says here. Also says they isolated it to the system bleeding down. I waited 4 days last week to start it and it started fine. I use it to plow so I am worried about cold starting, and the dealership said it will only get worse.
