Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems
Old 07-18-2009, 09:07 PM
Arrow white smoke??
what does it mean if your truck is cold and you start it and a cloud of white smoke blows out? ive noticed my dads does the same...any help would be nice. thanks eric.
Old 07-19-2009, 01:38 AM
WILD PHIL
Send a message via Yahoo to Powerstroke_soldier
Hey whats up Eric, You mean when the motor is cold, or when its cold outside?
Old 07-19-2009, 04:01 AM
FYI this is a FOR SALE section. The tech forums are listed on the main page.
Old 07-19-2009, 07:09 AM
Its normal to smoke some white when its cold. All diesels do it.
This should be moved to a different section.
Old 07-19-2009, 10:07 PM
whats up man, and when the motor is cold.
Old 07-19-2009, 10:15 PM
how do i change it and etc?
Old 07-19-2009, 11:40 PM
One of two minor things: fuel filter or dirty injectors. Replace filter, run a bottle of injector cleaner, should go away. Am currently having same issue on startup due to me being neglectful in filter maintenance. Hope this helps.
Old 07-20-2009, 12:41 AM
WILD PHIL
Yeah this should be moved to a different section, but I screw up some times to. Dont worry about it. And as Duraturd stated above it is normal for Diesel to spit alil white smoke when its cold. Especially when they have some miles on them. But taking care of your filters and stuff should take care of the problem. How many miles do you have?
Old 07-21-2009, 09:26 AM
212,000? im almost positive.
Old 07-21-2009, 09:36 AM
212k and only during startup? If the smoke goes away after a few seconds..
I would ignore it. Unburnt fuel
Issues? Most likely worn out glow plugs. Could be worn rings or sticky injectors when cold.
Again, ignore it unless it is REALLY bad.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.2
